Forum: Old versions
Topic: cue/bin section in recording
DJKraysHome userMember since 2005
i tryed it out and when i finished my mix went to copy to cd set error on line 1 of the cue sheet is there a fix 2 this or a program i can d.load 2 fix it?
geposted Sun 31 Dec 06 @ 5:59 pm
sbangsPRO InfinityMember since 2004
what disk burning program do you use ?
geposted Sun 31 Dec 06 @ 6:04 pm
i use nero but i have a program i use to test it b4 burnin to cd called virtual deamon manager which works wid everything else that uses cue/bin files ie films albums other cds so must be wid virtual dj makin the cue
geposted Sun 31 Dec 06 @ 7:21 pm
try making your mixes as mp3 files
then burning it that way
geposted Sun 31 Dec 06 @ 7:46 pm
its just 1 long track then and it kinda hard to skip songs u av to hold down the search key lol
geposted Mon 01 Jan 07 @ 1:21 pm
try another burning program
are you using the option Burn from image?
geposted Mon 01 Jan 07 @ 1:26 pm
i got it workin in nero now due 2 mate but he said it should work in a virtual cd drive 2 which it aint :S i know im buggin just want it to work fine as i know ppl play erm in virtual drives 2 test quality of it etc would appreacate it if u got solution if not no biggie :) :P
geposted Mon 01 Jan 07 @ 1:47 pm
to use demon manager
you need an iso file , only 5% of cue files are supported
as they simply contain info on how to make the disk
geposted Mon 01 Jan 07 @ 1:50 pm
so try winiso then lol instead of my deamon manager v4.03?
geposted Mon 01 Jan 07 @ 1:56 pm
no mounting a virtualdj recording on a virtual drive or a .cue in most cases it wont work
if you want to listen burn it to a disk
geposted Mon 01 Jan 07 @ 2:11 pm
henrydHome userMember since 2007
i recorded a session in the " burn cd" format. which recorded the session as a .bin/.cue file what program can i download to be able to first hear the session and then to burn it and lastly to convert it a different format such as mp3 or others?
geposted Mon 01 Jan 07 @ 10:23 pm
nero burning rom
geposted Mon 01 Jan 07 @ 10:25 pm
the .bin file is the data section. the .cue file is simply a text document that tells your burning sofware where to cut tracks. You can view/edit these in text editors like notepad. It may be worth while looking into the file and seeing if there are any obscure characters there.
Mykel
geposted Tue 02 Jan 07 @ 7:34 pm
