Topic: Hot Cue Buttons 1, 2, 3
The manual says nothing about these? It tells you how to make cues with the pause and cue button.
Thanks
geposted Mon 01 Jan 07 @ 6:18 pm
sbangsPRO InfinityMember since 2004
hot cue
1,2,3,4
let you jump to those cues once you have made them
to make one , click on the hot cue button at the point you would like it to be or right click and press ADD cue
gluck :)
geposted Mon 01 Jan 07 @ 6:21 pm
thanks sky i was gonna ask also......how does the loop work, what i mean is can you just click loop in wait for the verse to get to the end say and then click loop out at that point and just loop like that or can you onl y loop by choosing 4,8 16 beats etc???? i musta done something wrong
geposted Mon 01 Jan 07 @ 6:26 pm
you can adjust the lengh of loops via keyboard shortcuts
to check the list out its on my blog or just go to the keyboard shortcuts menu :)
geposted Mon 01 Jan 07 @ 6:28 pm
i gotta try some of this....can a deck load a new tune to an old previously saved cue?
when you load that song up again the cues remain
unless you delete them
geposted Mon 01 Jan 07 @ 6:30 pm
thanks
geposted Mon 01 Jan 07 @ 6:32 pm
thats alright ;)
geposted Mon 01 Jan 07 @ 6:35 pm
setting cue points are the key to mixing hip-hop
you can scratch the song in real easy if you add cue points
you can create sick mini-mixes with them
also, sample stuff in and you're set
press control button and then number 1
press control and then number 2
couldn't be easier
good luck
geposted Tue 02 Jan 07 @ 3:39 am
