Topic: Video Cards
I have a 128mb ati mobility radeon x300 card. Is that good enough? Can video cards be changed in a Laptop?
geposted Mon 01 Jan 07 @ 6:52 pm
sbangsPRO InfinityMember since 2004
yes if its not intergrated but you need to contact the manufacturer
geposted Mon 01 Jan 07 @ 7:04 pm
Yes it is Dedicated! Just got through taliking to the MFG!
geposted Mon 01 Jan 07 @ 7:52 pm
cool you can get it upgraded if you wish contact your local pc upgrade center and they can tell you what is abvailable or you can contact the manufacturers and ask their price usual more than a pc repair /upgrade shop
geposted Mon 01 Jan 07 @ 7:57 pm
You do mean upgrading the video card or ram?
geposted Mon 01 Jan 07 @ 8:00 pm
Did you try that card?
Might work ok with videos as it is ;)
geposted Mon 01 Jan 07 @ 8:02 pm
Yes i have tried it here at home with the trial version before i buy it. I guess it works okay. The videos load fairly slow. Would upgrading it to a 256 card will work better?
geposted Mon 01 Jan 07 @ 8:07 pm
yes , but 512 would be better :--)
geposted Mon 01 Jan 07 @ 8:12 pm
Yeah, better card will more ram helps ;)
Also the slow load on videos is a bit intentional too, to avoid skips when mixing videos (and loading a huge video file).
You can try to turn if off, by changing the SPEEDLOAD value to one in registry.
Might work fine with fast load, but it depends a bit on your PC :)
geposted Mon 01 Jan 07 @ 8:13 pm
How do you get into the Registry?
geposted Mon 01 Jan 07 @ 8:14 pm
oh.. if you dont know the registry well, stay out..
There is a tool, that will make the changes for you, that one can download from this website, that will change these values with an easy press&click.
But its for full users only.
If you feel comfortable going to registry:
In windows:
Start >> Run >> regedit.exe
Then search for "SPEEDLOAD"
Change the value from 0 to 1
DONT RECOMMEND YOU GOING TO REGISTRY IF YOU ARE NOT COMFORTABLE WITH IT!
IT CAN MESS UP YOUR WHOLE SYSTEM, IF YOU DONT KNOW WHAT YOUR'RE DOING
geposted Mon 01 Jan 07 @ 8:21 pm
go to control pannel
in the run box
type Regedit
then on the next window
search for vitual dj
look for the speedload key
change the value there from
0 to 1 ,
(be careful and take backups)
pro users have acess to a tool to do this
geposted Mon 01 Jan 07 @ 8:22 pm
So when i buy either VDJ or Numarks Cue i can download the tool to change the speedload in the registry? Then i can change it back with the same tool if i want to?
geposted Mon 01 Jan 07 @ 8:29 pm
yes :)
geposted Mon 01 Jan 07 @ 8:33 pm
I found the speedload key under virtuaj dj. When you right click it. It says New & then it has string value, binary value, dword value, multi-string value and expandable string value. Which one to choose to set it from 0 to 1?
geposted Mon 01 Jan 07 @ 9:05 pm
edit the actual key dont make a new one
geposted Mon 01 Jan 07 @ 9:08 pm
I don't understand ?
geposted Mon 01 Jan 07 @ 9:20 pm
Right-click, the Speedload in registry, and choose "EDIT"
Then write 1
(hexidesimal and desimal dont matter for the value )
geposted Mon 01 Jan 07 @ 9:24 pm
When i right click it. It says modify, modify binary data, delete and rename.
geposted Mon 01 Jan 07 @ 9:30 pm
modify ! ;)
Sorry, I have Norwegian Windows.
Choose MODIFY, and change the value to 1 :)
geposted Mon 01 Jan 07 @ 9:31 pm
