It would be nice if you could add a way for the XP10's and the DAC2 PITCH sliders to control the volume for the left and right decks.
If the DJ did not care about beat matching, he could use the sliders to raise and lower the volume for each deck like a mini mixer.
BPM Studio has this feature and it is great if you could add it to virtualdJ.
Thanks
WirelessDJ
Thanks
WirelessDJ
geposted Sat 07 Aug 04 @ 8:22 pm
Under virtual DJ 2.01, use the XP10 mapper to set the pitch slider as the LEVEL shortcut instead of the PITCH slider.
Yes you just asked it and it is already in VDJ.... Magic isn't it ?
Y.
Y.
geposted Sun 08 Aug 04 @ 7:41 pm
That's great! thanks
can you add some controls for the DAC2/DMC1?
geposted Mon 09 Aug 04 @ 12:40 am
