Topic: Buying the PRO version!
Hey all VDJ's.
Before i buy the 4.2 pro version of vdj i would like to know if:
The pro version really is more stable and better than the trial.
The pro version works with my ESI U46 (SN: ESJ051...)?
If it works along with BCD2000?
And, for how long into the future i can download the updates, uintil version 5.0?
geposted Tue 02 Jan 07 @ 9:54 pm
yes
they should be
what problems are they giving you?
aslo updates are for ever until other wise specified :)
ie 1,2,3,4 have been free to registered users
Well, ESI u46 wont work in ASIO mode, cause of overload. Once it actually worked, but next time i started vdj, it didnt.
And the bcd 2000, i dont have it, but ive read some posts abaot it, that says its bad with 4.1.
But the vdj bought over ESD, is that the pro version?
Good to see another Norwegian here;)
Here is what you do:
- Use the 1.014 driver for the U46dj (or later)
- Go to VDJ PERFORMANCE TAB, and choose LATENCY AUTO (important!)
- THEN, go to your soundcard setup, and choose the right input / output, and u46 soundcard
- and finally, go to Timecode Config, and choose AUTO CONFIG.
This should get you 100% steady timecode quality signal, if all is set up right
(remember to ground your turntables to your PC! )
Hope that helps ;)
Yeah.
You are from hordaland too. goodie.
What clubs are you playing in?
VDJ WERKS PERFECT WITH BCD2000 + v4.2 (NO FLAWS, NO OVER HEATING, NO SHUTTING DOWN, NO BLUE SCREEN OF DEATH)
how much is the bcd 2000 ?? how many faders ?? does it have jog/scratch wheels....i'm trying to drop in samples fade multiple samples up and down , loops on the fly and fun stuff i'm not used to doing in Traktor,and stinks doing it with mouse......of course the laptop is really the dj......lol
Wow. So you're telling us that VDJ 4.2 actually fixes windows problems? ;)
oh criminy.......
chucknorrisyouwimps wrote :
oh criminy.......
I'm just playing Chucky Boy. ;)
You saw my Mac hijack coming, didn't ya? =P
