Topic: 4.2 DAC-3 Mapper help!
Hi all... I have just updated to 4.2, but need the mapper... any help would be great thanks!
geposted Thu 04 Jan 07 @ 9:02 pm
You can download the DAC-3 mapper from Download -> Plugins -> External Tools:
http://www.virtualdj.com/addons/download.html?addon_id=2401
Copy dac3.dll from the .ZIP file to your VirtualDJ Plugins\\ControlDevice folder (E.g: C:\\Program Files\\VirtualDJ\\Plugins\\ControlDevice)
Read the DAC3Mapper text file included in the .ZIP file, which explains how the mapper works.
Start VirtualDJ, click on Config, then Remote Control and then tick DAC3.
You should see 809915 on the display as the mapper loads.
Thank you very very much!
