Hey guys,
I'm trying to get Virtual DJ 4.2r1 to work in ASIO _output_ mode with the kX Project drivers and a Soundblaster Live! 5.1 card. I can get the kX drivers installed fine and I do get audio output, however it seems that what should be playing through the headphones is getting mixed into the front speakers.
Anyone had any success getting this to work? I've tried looking at the DSP routing and ASIO routing settings within the kX mixer but that just baffles me :) I'd like it so that one audio output on the card can be used for monitoring while the other goes to the main speakers. Tried the 4.1 option in Virtual DJ but would this not give higher latency than using ASIO?
Any help would be appreciated, thanks.
geposted Sun 07 Jan 07 @ 11:42 am
do you get any options to assign channels =)
geposted Sun 07 Jan 07 @ 1:36 pm
Depending on which card you use you get a number of output devices. The one ending in 0/1 is always the mixed out of all channels on your main out.
output1 is device 2/3, output2 is device 4/5, output 3 is 6/7 and output4 is 8/9 (depending on availability)
So if you use output 0/1 for headphones you will also hear main out..
This is all well documented in the kX manual..
geposted Sun 07 Jan 07 @ 8:07 pm
Thanks guys. I managed to find a DSP setup for kX that routes ASIO channels 1/2 to the front output jack and ASIO channels 3/4 to the rear output jack. Now it works great with no skipping at 2.66ms latency (latency according to the driver anyway).
If anyone wants the setup let me know I can post a link or describe it. For those familiar with the kX mixer it's basically two 'src' devices wired up to outputs on a 'k1lt' device (you'd use the 'k2lt' device if you're using an emu10k2 based card). It bypasses the internal mixer of the card I think but still works ok for DJing and I can just go back to the regular setup if/when I need to.
VirtualDJ wouldn't let me choose any other ASIO outputs to use besides the two pairs 1&2 and 3&4, which is why I had to find some way to route those specific ASIO channels to the proper audio jacks on the card I wanted. With the default routings in kX, these ASIO output channels were being sent through some other processing/mixing path.
geposted Mon 08 Jan 07 @ 1:00 am
@fr0sty
Are you using tcvs with the soundblaster live and asio kx drivers? Once I tried to work with tcvs and 2 soundblaster live and kx drivers, but I couldn't break the channels for the tcvs' inputs and outputs even modifying the registry.
geposted Mon 08 Jan 07 @ 4:57 pm
sep frosty, I would like a link to the setup file if possible of the kx project. I've tried using this in the past but have had no luck.
thanks
thanks
geposted Tue 09 Jan 07 @ 6:37 am
Hey all,
The setup I used can be found here:
http://members.home.nl/nahutec/kxtutor/example.html
Just use the 'k1lt' plugin instead of the 'k2lt' plugin if you've got a 10k1 based card (like a Live).
I found that my system couldn't handle the latency at 2.66ms quite stably (VirtualDJ would occasionally stutter and would sometimes freeze up by BCD2000), so I'm currently using the 10.55 ms setting which seems to work ok. I think that's more to do with my system though than with the kX drivers.
I'm using the latest version of the kX drivers from their site and everything seems to work ok. I did notice that I had to reload my custom setup into the DSP once I'd rebooted (it had been set back to the default).
geposted Wed 10 Jan 07 @ 12:10 am
Is this really worth the hassle.. just get a decent (external) audio interface.. It wil save you a lot of hassle..
geposted Wed 10 Jan 07 @ 11:50 am
