Topic: newbie question...
A friend of mine let me borrow this software to determine if I want to buy it or not. I like what it does with one exception.....how do I cue track through the headphones without it going over the live mix? Right now I'm not using external hardware. I have an internal sound card that supports 7.1 surround. I use a 2.1 speaker system. That is plugged in the back. I do have a headphone output on the front of my PC, but it overrides all output to the speakers. I have tried every possible connection option I can think of, and no go. I even tried different settings in VDJ and nothing worked. The only thing I haven't changed is the advance options for my soundcard. It is a SigmaTel that came with my computer. Do I have the ability to cue only into a headphone output without disturbing the mix or will I need to purchase a new soundcard/software/hardware? Thanks in advance....
Dose
geposted Mon 08 Jan 07 @ 2:04 pm
choose 7.1 card
failing this 5.1
outputs :headphone
and assign the channels you wish to use for main and headphones
should work fine
Ok, I think I understand.....but where do I assign the channels, in the VDJ software itself? Also, I forgot to mention that on the advanced settings of my soundcard, it is set to "desktop speakers". Will it matter where I plug in my headphones and speakers at that point or will that be apparent on the channel assignments? Sorry for the stupid/basic questions, I have never messed with sound settings before. Thanks for the help and reply, I really appreciate it!!
on virtual dj
you will see the channel options on the sound setup page
and
look for 7.1 mode on ur sound software/driver config
Ok, sounds good! I'm currently at work, but when I go home for lunch or after work, I will try it and let you know. Thanks again for all your help!!
You might also wanna ask your 'friend' how he does this..
Right now it smells more like you're using a cracked copy and are trying to get a free ride. Care to share your 'friends' username here?
