Topic: ?> loose all the analyzed information
Will I loose all the analyzed information of my “Local Database” If I Right click on “Local Database. Select Delete CD, remove a CD from Search window opens,, remove c, d, f, info…. ???
geposted Mon 08 Jan 07 @ 10:03 pm
sbangsPRO InfinityMember since 2004
yes that will wipe all of those songs from search and the database and is not reversable with out a reanalize
geposted Mon 08 Jan 07 @ 10:17 pm
All right then try this one for size;;; I deleted songs from a folder on Disc F,, empty Trash Bin, rebooted, rescanned Drives…. VDJ still show the Songs in the folder that I deleted them from>>>> :(
geposted Mon 08 Jan 07 @ 10:24 pm
nope
geposted Mon 08 Jan 07 @ 10:35 pm
skyfxl wrote :
nope
What?
geposted Mon 08 Jan 07 @ 10:37 pm
Virtual DJ has 2 database files :
Virtualdj database.xml contains bpm, cues, gain info etc for ALL files you have EVER played or analyzed in VDJ.
ALL these files does not have to be part of the SEARCH database, that is made in the mp3database.txt.
So if all mp3s in say your "party-party" folder where analyzed, the info would be kept in the XML, even if you choose to "remove from search database" when you right click the folder.
The files will then NOT be in the search database, and if removed from favorites, not inside VDJ at all.
If you later want to add it back, just add it to favorites, right-click and "add to search database" and its instantly added (all bpm, cues etc. as they are already in your XML file)
Hope that helps;)
geposted Mon 08 Jan 07 @ 10:50 pm
cstollPRO InfinityMember since 2004
Incorrect, deleting from the 'Local Database' does not remove BPM/CUE/Analyzed data.
As DJ-in-Norway mentioned that only occurs if you delete the XML file.
geposted Tue 09 Jan 07 @ 12:22 am
So The info for each analyzed song is stored,,, After deleting, rescan and track that VDJ finds will be displayed as analyzed.
geposted Tue 09 Jan 07 @ 3:12 am
l_ridsPRO InfinityMember since 2003
Yes, all the info is stored in a separate file. I add & remove drives all the time during my gigs because I have multiple partitions of different music.
When I decide I need add them again, all the info is still there. No need to worry!
geposted Tue 09 Jan 07 @ 3:29 am
