Topic: numark cue
Can anyone tell me if im wrong,
can i get effects and plug ins for numark cue the same way that VTDJ pro users do?
ive tried to download some things and it tells me that i cant,
also can i use time code vinyl to control the cue software, if yes witch timecode vinyl.
thank you.
geposted Tue 09 Jan 07 @ 3:08 pm
yes if you bought it add your serial
i have added it, when i look at my profile i see the MK2 and the Cue user delimiter, however when i post on forums i only see the mk2 logo not the numark cue, also cant get any effects or plug ins....
maybe my profile needs to be modified?
Thanks Skyfxl,
you seem to be one of the most helpfull people here, I always see your good coments.
and you seem to know your stuf.
this is my level maybe it needs to be changed?
Current accreditation : Home edition user (level 1)
got this form my profile
and it says" you have purchased numark cue"
add your serial again to be sure then
contact support
fixed:)
horray =)
thnx----on to play...
