does anyone here use a keyboard to map the 12 channel sampler
this way you could change the pitch control etc. and create different effects
also, is this possible?
thanks in advance
thanks in advance
geposted Wed 10 Jan 07 @ 6:34 am
not quite getting what it is that you want to do...
if you could be a bit moe specific, it would be great...
cheers
DJ Rudra
cheers
DJ Rudra
geposted Wed 10 Jan 07 @ 6:52 am
I think he wants to map the sampler like a mixer with a keyboard.
so he can adjust pitch and be able to use it like 12 more decks
did I understand you?
DJ Marcel
Purple Onion Nightclub
DJ Marcel
geposted Wed 10 Jan 07 @ 7:08 am
i would like to use my "piano" keyboard as a sampler
i figure the only way to do this is to assign the vdj sampler (channels 1-12 on the basic skin) to various keys on the "piano" keyboard
is this possible?
does anyone do this?
i'm not using the keyboard to mix--i use my rane mixer for that
thanks
is this possible?
thanks
geposted Wed 10 Jan 07 @ 7:45 am
you can do this :)
hook your keyboards midi ports to your computer.
on remote control , enable "midi control"
then procede to map the keyboard
midi mapping
just repeat until the desired actions are all added.
midi mapping
geposted Wed 10 Jan 07 @ 1:54 pm
I've tried this, and it works okay for some keys, but not for all. I also have a hard time getting the sliders and knobs working. Sometimes I get the same midi-value from the knobs as I get from the tangents. The keyboard works flawless in other music progs, and as far as I've understand (and that ain't to far) it has to do with midi-channels. Seems like VDJ doesn't handle more than one. Am I right? Can someone please explain?
geposted Wed 10 Jan 07 @ 3:00 pm
thanks i will try but first i will order the usb piano keyboard
anyone have any recommendations on a keyboard?
geposted Wed 10 Jan 07 @ 4:06 pm
if u just want a midi controler usb one
http://www.technokit.co.uk/proddetail.php?prod=EST036&source=froogle
geposted Wed 10 Jan 07 @ 4:11 pm
thanks for the good info
just one more question
is there a way to play the keyboard through vdj rather than mapping it to the turntable or sampler?
can i play drum beats through it and record it?
can i play samples through it without having to load the vdj sampler and map it?
thanks all
after this i am buying a keyboard usb controller
thanks all
geposted Thu 11 Jan 07 @ 4:36 am
theres no beat generation in virtual dj
so it wont create beats over midi , but if you get a full keyboard with midi and take the line out of the keyboard into an input on your soundcard you can play it that way.
geposted Thu 11 Jan 07 @ 9:38 am
so in other words you are suggesting i run my keyboard through my mixer and bypass vdj?
or---are you saying i can put keyboard into sound card input and it will play but not in vdj?
maybe i will just load samples in the sampler and map keyboard for the 12 of them
hmmmmmmm
hmmmmmmm
geposted Fri 12 Jan 07 @ 5:37 am
if you want a keyboard note/ drum pad notes use the keyboard ouput
if you want samples use midi
geposted Fri 12 Jan 07 @ 10:33 am
have you looked at the ue33 mixtable?
http://www.virtualdj.com/products/hardware.html
geposted Fri 12 Jan 07 @ 10:40 am
I kinda know what you mean. I would like to see an improved sampler on vdj. Ive used ableton and i still prefer to dj with vdj. If the sampler could be upgraded into something similar to ableton with audio and tempo controls on each channel and effects it would allow incredible remix and even production opportunities. I think its the way VDJ should go, its cracked the dj side, now it should move on to the remix/production side for people who really want to mash up their music.
just an idea
just an idea
geposted Fri 12 Jan 07 @ 12:06 pm
its been sugested to have a composer , to make beats and to sample better :)
will have to wait and see
geposted Fri 12 Jan 07 @ 4:14 pm
thanks to one of the other companies who i test for
in the market of goverment and corporate defence and security softwares who shall not be named
i now have a new midi keyboard/controler , so il map mine and tell u how it goes :)
geposted Mon 15 Jan 07 @ 3:09 pm
