Topic: HUMMING PROBLEMS
hi all
i recently bought the mark 2 hercules mixer and when i run it on my desktop i get nominal noise but when i run it thru my laptop and out into a boss 303 dr.sample and into an amp i get a really bad squeely hum as im using this to dj i dont need the extra noise as it is bloody embarrasing!!! LOL
can anyone help?
PLEEEEEEEEEEEAAASE!!! :(
Dj.De'Mensha
geposted Wed 10 Jan 07 @ 10:31 pm
try plugging your laptop into a different plug than the amp :) and mixers
could be current noise
I had this problem also, for some solutions read..
www.virtualdj.com/forums/49420/General_Discussion/Very_loud_humm_sound_when_using_laptop.html
Cheers
Grug
thankyou so much chaps!
i shall check this out and get back to you if no joy
many thanx :)
yep all fine when i run without mains cable but obviously only short amount of mixin time b4 battery rus dry!
will chase down one of these little kerjiggers to stop humming as i think disconnecting earth could inevitibly fry my system
thanx again for helping guys i relly apriciate it
Dj De'Mensha
*Get a ground loop eliminator... every dj should have one, at least if you play different venues.
Its cheap, and can be bought on local radio stores
