Topic: Karaoke gig tonight
I normally don't do Karaoke BUT tonight my rest/bar called and asked me to do a FILLIN!
Can someone answer me a question?
If a singer wants me to change a key or pitch (I know how to pitch change) but how do I key change??
I know last minute but I Thought I would give it a shot!!
geposted Wed 10 Jan 07 @ 11:47 pm
If you are using 4.0 or above there is a plugin in the effects section called key changer. Just activate and slide. I belive it is in 1/2 step incriments.
In 3.4 there is a key changer plugin you can download. Does not work as well though. When you activate if it goes down 3 semitones automatically, you need to be ready to adjust it. I belive that keys down in full steps only. check here about 1/2 way down the page: http://www.virtualdj.com/addons/view.html?type=sound%20effect&page=4
