Topic: i need help!!
hi all
i have 2 quesions.
1) i havejust got a new pc and want to transfer all my vdj xml library over to it. is there anyway i can do that (eg tracks analyzed, bpm's etc.) or will i have to scan all my tracks again.
and also
2) i saved my original vdj exe file to disk so that i can install it but i dont have the updates saved is there a way to get them again.
thanks
dave
p.s. to everyone, All the best for 2007
geposted Fri 12 Jan 07 @ 8:59 pm
You should be able to save your database to a disc or thumb drive, and then copy it to the new computer. E service will help you with the license transfer.
yes , copy mp3database.txt , virtualdjdatabase.xml , virtualdjdatabase(yourname).xml to the new pc :)
as to the update
contact as there
