Hi
I have a gig tonight and my internal soundcard is playing up and need to buy an external soundcard. This is just to get me by tonight;
Will this work/do the job;
http://www.argos.co.uk/static/Product/partNumber/6767536.htm
Thanks
Craig
Thanks
Craig
geposted Sat 13 Jan 07 @ 4:43 pm
that should be fine mate
will do headphone preview aslo
whats wrong with the internal?
geposted Sat 13 Jan 07 @ 4:48 pm
Thanks I 'm going to run out and buy it!!!
I get an error message along the lines of missing driver. When I take the top of the pc and nudge it with my finger and then reboot it, it works. But I can't have it doing that part way through a disco.
I am only a mobile dj but I have a wedding to do tonight.
Thanks again
Craig
Thanks again
Craig
geposted Sat 13 Jan 07 @ 5:28 pm
sounds like the card has partialy come detached inside
geposted Sat 13 Jan 07 @ 5:37 pm
skyfxl,
I have got the external soundblaster now. Can I just it in and change config in VDJ and roll? OR do I need to install stuff off the disk for it?
Hopefully the disc contains other stuff that I don;t need at the moment.
I will get the internal card out and get it checked out by a technician or something.
Thanks
Craig
Thanks
Craig
geposted Sat 13 Jan 07 @ 6:25 pm
if windows picks it up straight away , can just roll , if it doesnt use the disk :)
geposted Sat 13 Jan 07 @ 6:37 pm
Thanks for your help. It's much appreciated!!!!
This is why I love this forum. Not only fantastic software but fantastic support from all!
Cheers
(Keep your fingers crossed for me tonight!!)
Cheers
geposted Sat 13 Jan 07 @ 6:57 pm
The USB external soundblaster worked after I installed the software, BUT.............................................i had a problem.....
A track was playing say in Deck A, when I loaded a track in Deck B the sound from Deck A slowed down and it was very noticeable!!
What do you think was causing this??
During the break I changed back to the internal card and took a risk with it. Fortunatley this was OK and the night went well.
Any help woul dbe appreciated.
geposted Mon 15 Jan 07 @ 11:14 am
try this
lower your proformance tab and choose autolatency
and ensure both boxes are unticked
geposted Mon 15 Jan 07 @ 11:44 am
