OK, it real simple. I did the 4.1 upgrade and the sonique effects from the download area are freezing my program. The second I hit activate everything stop dead except the outgoing video and audio. If I get this little issue fixed i will have a perfect program because after the update there are no more glitches. Thanks, Mike
geposted Sun 14 Jan 07 @ 8:49 pm
have you looked at the 4.2 update?
what is ur spec ?
what is ur spec ?
geposted Sun 14 Jan 07 @ 9:06 pm
