BECOME THE ULTIMATE DIGITAL DJ!
The iCUE is a complete DJ workstation which allows you to mix audio files directly from your computer. The iCUE features the world-class CUE DJ software and a dedicated controller, allowing you to scratch, control pitch and automatically beat match digital music. But that is not all. With built-in sampling, looping and effects processing capability, the iCUE lets you take your mixing to the next level. And with the built-in recorder, you can record your mixes on the fly and burn them on CDs. The iCUE also features video support so you can play, scratch and add effects to video files, making the iCUE an incredible multimedia mixing system.
Key Features:
- CUE professional DJ software included
- Big wheels for scratch, effect, and speed control
- Crossfader
- Level and pitch controls
Le novità sul mondo delle console digitali iniziano ad arrivare!
Dovrebbe gia essere compatibile con l'ultima versione di Virtual DJ 4.2 e del Numark Cue e direi che non è fornita di scheda audio, sembrerebbe una ottima antagonista della Hercules MP3 ;)
Fonte http://www.ion-dj.com/iCUE.php
altre info http://gizmodo.com/gadgets/gadgets/ion-icue-and-imx05-lets-amateurs-dj-like-novices-227202.php
Key Features:
- Crossfader
geposted Mon 15 Jan 07 @ 2:03 am
