Once in a while about every 4th or 5th song, it seems to not load instantl when dragging to a deck, but takes about 20-30 seconds? What may cause this?
geposted Mon 15 Jan 07 @ 8:09 am
try reducing your proformance tab :)
and try some of the optimisation tips on my blog
geposted Mon 15 Jan 07 @ 10:29 am
Also, do you have a power-save settign turned on for your hard drive? If so, it may be powering down and so you need to wait for it to power back up before you can access it. I had this problem in the past.
geposted Fri 19 Jan 07 @ 5:30 pm
Is it after you have loaded a video?
VDJ will intentionally load songs slow after video play, to prevent skips in video.
This safe guard feature can be turned off, to test if your PC dont need it.
Its called SPEEDLOAD in registry, and change value to 1
geposted Fri 19 Jan 07 @ 5:47 pm
"Posted Fri 19 Jan 07 @ 11:30:30"
"Also, do you have a power-save settign turned on for your hard drive? If so, it may be powering down and so you need to wait for it to power back up before you can access it. I had this problem in the past."
Is this a feature in both Int. and EXt. HD's? And where do I locate that setting in either or both HD's?
geposted Sat 20 Jan 07 @ 10:34 pm
on windows control pannel
under power managment :)
geposted Sat 20 Jan 07 @ 11:02 pm
