Topic: Karaoke Input With Echo?
I now have to do karaoke, but how do I connect the microphones to a standard mixer and add echo?
At the pub they have a Numark CM200 USB mixer installed that I plugg my hercules into (I know the nunark CM has USB, but I havn't figured out how to make it work with virtual DJ yet).
The thing is all my microphones are XLR so I need some sort of adaptor box to plugg them into (minimum two mics), that has echo or reverb for the karaoke
with standard RCA outputs . Any ideas what I need? Or are USB microphones any good? Even if you can't get a box to plugg XLR into, I can always cut the ends off and put a different connector on the ends of my mic's.
Hope someone has some ideas? At the minute I'm having to use my Studiomaster powered mixer
just so I can get echo. It's one heavy bit of kit.
Cheers.
geposted Mon 15 Jan 07 @ 3:12 pm
you might wana try a small line and mic fx mixer such as beringer
UB1204FX which comes in a 2 input and 4 input model
and is quite light :)
Yeah that would work, but still would take up almost as much space on the desk and again seems like alot just for me to add echo.
Also I don't want to spend too much like I keep saying I just want to add a bit of echo for the singers.
Can I buy something like this:
but instead of the dials for volume controll they were for echo controll?
Or better still, can you buy microphones with echo built in? Just adjust it with a dial or a screw on the side before giving it to the singer?
Something like this would be great, obviously not for kids! lol.
Check this out,,,,, I'm trying to downsize my set up from vocoprokj8000pro and adding BCD2000....Trying to Find a small microphone effects mixier , If I do I'll be selling my kj8000..
http://www.pssl.com/bitemdetail.tpl~waGroup1datarq~[waGroup1datarq]~eqint_KeyIDdata~33133~itemNumber~KMX-01%2001%20%20%20%20%20%20%20%20~UID~2007011506212793~disp_IMG~Y~catgroup~%5BcatGroup%5D
http://www.planetdj.com/i--KARAOKECONSOLE
Try hercules's karaoke console.
I have NO idea how good/bad it is.
Going by they're DJ Console - it'll be middle of the road.
But price is right and it'll do your karaoke gigs for you
DJ Marcel
DJ Marcel
Oh Good,,, Another Fisher Hercules Price toy..
Looks more like a stand-alone karaoke thingy, doesn't say if it will work with virtual Dj or not, as I now use firtual DJ to play the karaoke files I don't want to have to mess about with different software.
Vocal eliminator.
Vocal eliminator isn't much use if you don't have the words on the screen. Besides like I say I'm using Virtual DJ to play my karaoke files.
I've seen the microphone control plug-ins in the download section, is there one that allows echo? That way I could plugg all my mics into the hercule's or another sound card.
