Topic: Newbie question relating to saving file.
I'm having a hard time finding a specific answer to my question when I search the forums and I'm hoping someone can assist. When using ATOMIXMP3 (just figuring things out) how do I save the mix that I'm working on?
Any help would be appreciated.
geposted Mon 15 Jan 07 @ 5:41 pm
go to recording on the main skin
you can save as wav or mp3 or to disk
you will need to record the whole mix
WAV uses more disk space - you need the LAME encoder to record to MP3 - I believe it's been added by default to the latest version.
You can split the files using the crosfader, so you don't end up with a single track running for several hours - and you also need to devote all your time to doing it - forget the telly, meals and stuff like that - unless you can have your meal in the room where the computer is and eat while you're mixing.
With AtomixMP3 you can't record in .mp3, you can only in .wav
thank you for this advice support team :)
Thanks for the responses. After looking I did find the save feature. I do have one more question.. when you have a song playing and one in cue, how can you hear the 2nd sound so you know where you want to fade in the 1st song?
Thanks again for your help
for prelistening you need a 4.1 soundcard or better
and choose on options
one card , headphones
and choose your card
