Topic: Newbie question relating to saving file.
JumbieHome userMember since 2007
I'm having a hard time finding a specific answer to my question when I search the forums and I'm hoping someone can assist. When using ATOMIXMP3 (just figuring things out) how do I save the mix that I'm working on?
Any help would be appreciated.
geposted Mon 15 Jan 07 @ 5:41 pm
sbangsPRO InfinityMember since 2004
go to recording on the main skin
you can save as wav or mp3 or to disk
you will need to record the whole mix
geposted Mon 15 Jan 07 @ 8:04 pm
WAV uses more disk space - you need the LAME encoder to record to MP3 - I believe it's been added by default to the latest version.
You can split the files using the crosfader, so you don't end up with a single track running for several hours - and you also need to devote all your time to doing it - forget the telly, meals and stuff like that - unless you can have your meal in the room where the computer is and eat while you're mixing.
geposted Tue 16 Jan 07 @ 3:26 pm
With AtomixMP3 you can't record in .mp3, you can only in .wav
geposted Wed 17 Jan 07 @ 10:33 pm
thank you for this advice support team :)
geposted Wed 17 Jan 07 @ 11:24 pm
Thanks for the responses. After looking I did find the save feature. I do have one more question.. when you have a song playing and one in cue, how can you hear the 2nd sound so you know where you want to fade in the 1st song?
Thanks again for your help
geposted Fri 19 Jan 07 @ 5:34 pm
for prelistening you need a 4.1 soundcard or better
and choose on options
one card , headphones
and choose your card
geposted Fri 19 Jan 07 @ 6:11 pm
