Topic: Virtual DJ and Virtual Vinyl Questions
Hi my name is Kenny,
I have been a DJ since 1984.
I bought Virtual DJ a couple of years ago in Atlantic City but never used it.
I am seriously considering getting into video mixing and getting Numark’s Virtual Vinyl (whenever it is released). I am also considering getting the Numark D2 (whenever it is released) for my mp3 files. I've been using PCDJ for years and have over 500gb filled with music.
I have several questions about Virtual DJ.
1. I use x-keys controllers for my systems. I have many of PCDJ's commands programmed into the keys and want to use the same PCDJ shortcut commands for Virtual DJ.
- Is there a way I can change Virtual DJ's keyboard shortcuts to match PCDJ's? (please explain with detail).
2. Can I use a keyboard shortcut command to load a song? (I don't like the drag and drop option)
3. When virtual vinyl comes out. I would like to use ONE turntable and use a keyboard shortcut to control both decks (This is possible with Serato Scratch Live).
- Is it, or will this be possible with Virtual Vinyl?
4. Will I be able to record my video mixes onto DVD with decent quality?
5. Does Virtual DJ read ID3 tags?
6. Can I play my Karaoke files the same way as with PCDJ?
Thank you,
I've been reading posts from this website for about a month now and I am anxious to start mixing video as soon as I get a laptop with a good video card.
geposted Tue 16 Jan 07 @ 4:15 am
I would also like to program all of the samples into individual keys for my X-Keys controllers.
Please help
These are the X-Keys controllers that I use:
The X-Keys (58 key) proffessional and the X-Keys foot pedal.
check it out.
www.xkeys.com
-Kenny Q
Why buy any more, you have all that you need in VirtualDJ - Numark VV is VirtualDJ with the Numark logo and VV name. No need for the D2, it's stand alone - won't interface with anything.
VirtualDJ will do your video and audio mixing all in one.
Since you mentioned you bought VDJ a couple of years ago. Send a message here http://www.virtualdj.com/contact and see about getting updated to 4.2 - which depending on what you bought - the upgrades may be free. I think you will be really amazed at the improvements.
cstoll
Thank you skyfxl and cstoll, for replying to my messages.
Skyfxl.
I am very familiar with making macros with the x-keys software.
I am interested in matching Virtual DJ’s keyboard commands to the ones that I have from PCDJ, this way I wouldn’t have to create new macros.
Cstoll.
You asked: why buy Numark D2 and Virtual Vinyl when I already have Virtual DJ?
- It looks like I can eliminate using a computer with the D2, I can afford it and if it may make my job easier, Why not?
I do want to use a computer if I get into video mixing. I figure that I can use the Numark D2 for mp3s and a laptop if I need to use videos.
You also asked: Why Buy Virtual Vinyl when I already have Virtual DJ?
- I bought Virtual DJs time code vinyl but my sound card is not compatible.
I don’t need Numark’s software but I would like to have their soundcard which is built to support the software without problems.
Thanks again for your replies.
info on shortcuts
http://www.virtualdj.com/blog/skyfxl/blog3774.html
and making new ones
look at the image on that blog to check for the ones which exist
now press add
now
choose the funtion you want ,
its all explained in the window as what funtions do
ie Deck 1 play can be mapped to T
so you could make play 1 as T then add send T on the x keys
Thanks for the quick reply,
Is there another way of loading songs instead of drag and drop?
Can I use a keyboard shortcut?
-Kenny Q
yes you can , i think there is one check the chart on my blog
if it isnt there
choose
browser > browser open
then assign 1 or 2
ul need 2 shortcuts
one for deck 1 and one for 2
Kool,
I can’t access your blog from the computer that I am currently using but I will check it out tonight using another computer.
Thanks,
- Kenny Q
Thanks Skyfxl,
You were a lot of help.
I now understand how to change the keyboard shortcut commands.
-Kenny Q
any time =)
