Topic: How do a broadcast with virtual dj 3
how do i broadcast with virtual dj
geposted Tue 16 Jan 07 @ 11:29 am
so were can i get the 4.2 from ?
it says (warning the skin you are trying to use has a higher resoltion than your screen.)
what shall i do.?
try another skin
what is ur resoultion
what shall i do.?
The screen (monitor) resolution is lower than the VirtualDJ current skin resolution.
Try to increase your monitor resolution.
please aslo ensure that your sound config is correct as this can lead to direct x errors which can cause the resoultion problem
