Topic: VDJ Playlists
Hey, I have a problem, I use to be able to save my playlists whenever I use VDJ, and now in the playlists folder THERES NUNN :(:( , and i did a great set, and i wanted to recall what songs i used and now theres no playlist????
geposted Sat 20 Jan 07 @ 11:04 pm
well if u must insist on using a bad copy :(
what do you expect
i think its time for u to buy the program now if you intend to use it seriously and want the benifits of doing so.
hope to see you as a pro user soon :)
I disagree as I have the very same problem. I recently upgraded to 4.2. Sometimes the playlists save and sometimes they don't. I didn't notice this until I went looking for a song I played a few nights ago.
I agree, my playlists save but if I rename them, they somehow dissappear!
It's nothing to do with a bad copy, its me looking for my playlists
Well, you do use a cracked version, and a really old one too...
But also the newer demo, so guess thats where your playlist question comes in.
Playlist are not auto saved anymore, after version 4.x, but it can be turned on, using DJ Cels registry tool.
But its only available for full registered users, and I do hope your time is soon ;)
If you like the software, and guess you do:)
same problem happened to me.
but there is one way.
file: history.txt
it's located in your virtual dj program folder.
DJ Shahar
www.djshahar.com
