it would simplify all of our lives if vdj had a configuarion wizard.
it would scan the computer for the specific hardware.
cpu, ram, sound card, mouse, keyboard, monitor, etc.
then, it would ask the user some additional stuff.
example: would you like to use tcv, tccd, or none.
explaining what each item is.
after that, it would make a two column list of taks needed to be made for optimal settings.
on the left: description of the taks.
on the right: check box
on the bottom of the page: perform checked boxes.
the most important thing is to config the soundcard and usage.
____________________________example___________________________________________
scan complete.
wizard detected a hercules dj console mk2 which is compatible with time codes.
would you like to use time codes? {yes} no
please connect your time codes hardware and press scan {scan}
scan complete.
setting up time codes configuarion
hercules dj console with 1 TCCD (timecoded cd's) have been setup.
your monitor screen resolution is 1440x900 but you do not have any skins at this resolution.
click here to download additional skins from virtualdj.com. {next} | continue | skip skin wizard
you have skins supporting 1024*768 and your monitor supports this resolution.
would you like to resize your monitor to 1024*768? Yes {No}
_________________________________________________________________________________
how about this?
DJ Shahar
www.djshahar.com
scan complete.
scan complete.
how about this?
DJ Shahar
www.djshahar.com
geposted Mon 22 Jan 07 @ 7:39 pm
          its quite simple to do these things now with the sound config options alot of softwares you would have to route audio and edit all the channel settings
aslo there would be to many hardwares to add to such a wizzard for example things like timecode cd these are different for almost every cd player so it would be very hard to a wizzard to work it out.
could help some users but could anoy some users aslo
windows issued such a wizzard before vista came out it had many issues with acuracy in detection of software and hardware the company with the wizzard would need to have all of the available hardware on the market as a list of settings , and would need to update this regulary
might be useful but not sure it would always be pratical
thanks for sharing :)
geposted Mon 22 Jan 07 @ 8:15 pm
          my main conern is the "performances" tab.
skins, soundcard, whatever, we can somehow manage to get passed that stage.
but the performance tab. no one has a clue how to work it.
geposted Tue 23 Jan 07 @ 6:13 am
          its quite simple , you start low , then move up until your computer exeriances a problem then you set it a notch below that level :)
    geposted Tue 23 Jan 07 @ 3:47 pm
          and if in doubt choose autolatency and put it on its fastest
          but wouldn't it be nice if vdj did that for you?
that's the new feature i'm talking about.
DJ Shahar
www.djshahar.com
DJ Shahar
www.djshahar.com
geposted Wed 24 Jan 07 @ 1:16 am
          not realy because it woudlnt fit every ones machine as every one has a different peice of kit and they need to have a play to get the best out of it :)
    geposted Wed 24 Jan 07 @ 10:37 am
          come on...
you know where i'm getting at.
"auto config" should automatically configure vdj to the user machine.
geposted Wed 24 Jan 07 @ 5:54 pm
          i like the concept but , a report on many machines would have to be collected and stored as definations which would need some sort of webupdate so that it knows what to choose ,
just would take alot of time effort and potentialy capital expenditure if u get me :)
which at the moment is being directed into mac , virtual vinyl ect .
geposted Wed 24 Jan 07 @ 5:59 pm
          oh.
mac, who cares about that?
the tccd is working fine.
w/e
w/e
geposted Thu 25 Jan 07 @ 8:49 am
          lol dont say that conquest will hear u =)
    geposted Thu 25 Jan 07 @ 12:31 pm
