Topic: gain problem on headphones
I am working with vdj using kdj-500 for kontroller.
A couple of days after I fixed the headphone eq in the registry suddenly I lost control of the gain on my headphones only.
So I can gain on the speakers but if I listen to the same chanel on my headphones gaining doessent do anything.
Has anyone encountered this problem before and is there a solution.
Thanks
geposted Wed 24 Jan 07 @ 1:04 pm
are you using the latest demo
No I am using v.4.2r1
as a pro use you have acess to a tool which allows you to change this with no poking around in the registry
hope to see you as a pro user soon :)
Please just tell me what value it is a should be looking for in the registry.
Thanks
will get back to you on this one.
