is there a way to play, say a video such as a movie, while mixing two tracks? i want to have a movie playing while i mix live linked to vdj.
geposted Wed 24 Jan 07 @ 6:01 pm
unfortunately not at this time
possible future feature hopefuly :)
however for now :) you can play a video fx on audio files
go to video options and tick use plugin with audio
try the Sonique visuals there so pretty :)
geposted Wed 24 Jan 07 @ 6:11 pm
you could open a second instance of VDJ and have the movie playing on that, while you play music on the first instance.
Not ideal but might help a bit if your really stuck! :)
geposted Wed 24 Jan 07 @ 6:37 pm
could try a mutliinstance skin :)
geposted Wed 24 Jan 07 @ 6:44 pm
Sky,
Are you referring to a special skin that is designed around multiusage, or simply having two separate skins called up at the same time?
geposted Thu 25 Jan 07 @ 2:39 pm
any skin called multi instance
http://www.virtualdj.com/addons/skins.html
here will run 4 decks at once via running 2 instances in the same skin
geposted Thu 25 Jan 07 @ 3:09 pm
Sheesh,
I did not see any called "Multiskin" in their title. Did I miss sumpin?
geposted Fri 26 Jan 07 @ 2:46 am
bryantpb wrote :
Sheesh,
You need a skin that says "Multi Instance" not "Multi Skin"
geposted Fri 26 Jan 07 @ 8:03 am
