OKay I've been experimenting with the video component. The Club isn't using it but I'm stting a video comp for mobile sub contracting.
I've noticed when mixing audio with the sonique plugin running all works well - looks nice and all that fun stuff.
The trouble is when I want to disable the plugin I de-activate the plugin and it does not de-ativate instead it goes to all the pre-veiw windows on the video skin and there is no way of turning it off short of changing skins for a song or two and then changing back
This doesn't seem normal
makes me kind of nervous about using the video component.
DJ Marcel
Purple Onion NightClub
DJ Marcel
geposted Sat 27 Jan 07 @ 8:54 pm
in video options do you have "use this plugin for audio files enabled "
geposted Sat 27 Jan 07 @ 8:59 pm
It does not seem to matter what I do in the program settings - the plugin will not shut off untill I de-activate the video output wndow/tv out.
clicking on the activate button doesn't seem to do anything.
this is strange to me - is this a bug?
I'd rather not use this component untill I know I can fully control it
DJ Marcel
DJ Marcel
geposted Sun 28 Jan 07 @ 4:11 pm
thats very strange doesnt do it for me il get back to you on this
geposted Sun 28 Jan 07 @ 4:34 pm
If you have it checked in the Video settings tab then you have told VDJ to use this plug when something other than a video is loaded. So what you are experiencing is true - you won't be able to de-activate it from the skin. The reason it de-activates when you turn the Video Window off it's because you are De-Activating the video output (i.e. turning the TV off)
When you use the "Use this plug-in when audio is playing..." it's an all or nothing. I don't use it - I manually activate the plug-in so I don't have to deal with it not shutting off or activating when I want it to happen. Add, plus what it is 2 seconds of effort at the start of a gig to turn it on if you are going to start with audio.
cstoll
cstoll
geposted Sun 28 Jan 07 @ 6:38 pm
i noticed it. It seems to be a bug :s
geposted Sun 28 Jan 07 @ 9:56 pm
Actually cstoll - I first noticed this little glitch before I checked the "use for audio" box.
then I read sky's post and gave that a try
then re-checked th box.
then checked everything
then unchecked everything
Then jumped up and down on my office chair, flung some poo at the wall, stood on my head and srcatched my butt and finally ended up on the floor sucking my thumb in the fetal position.
But Seriously, i can't get the thing to turn off.
looks great while working. Really hope I can figure it out.
geposted Mon 29 Jan 07 @ 1:33 am
OKay after much playing around I have finally admited defeat.
I cannot for the life of me get the visualization to stop visualizing after activating it.
The only way that I can get it to stop is to disable the video output window and then re-open it at a later time. Even just instantly double click type stopping.
It will not for the life of me turn off by de-activating.
geposted Tue 30 Jan 07 @ 6:05 pm
you dont have to disable video, just disable Sonique as standard non-video effect, and THEN disactivate Sonique in effect browser. You can also activate it again in effect browser...
geposted Tue 30 Jan 07 @ 7:04 pm
