Forum: Old versions
Topic: Faderfox DJ2 Midi Mappings - anyone done them??
Hi
If anyone has done the Faderfox midi mappings I'd be very pleased to have them.
If I don't hear I'll try to map it myself, but I've found it a bit confusing so far.
A
geposted Mon 29 Jan 07 @ 12:07 pm
sbangsPRO InfinityMember since 2004
i dont have one but what are you finding confusing :)?
geposted Mon 29 Jan 07 @ 12:40 pm
Hi Sky
Thanks for replying. I've done quite a bit of it, but just messing about trying to finalise some bits. I want to map the browser up down rotary buttons so that when I press them down (activate the down switch) they will load the song to the relevant deck. Somehow I can't seem to find a midi command on the VDJ list which will load a track to a deck.
Also I'm having trouble with a tempo control (pitch slider) but will probably figure that out.
A
geposted Tue 30 Jan 07 @ 2:16 pm
abnormPRO InfinityMember since 2003
Just wondering if you figured out how to use the 360 degree knobs? I have a Faderfox DJ1.
geposted Tue 03 Apr 07 @ 1:40 am
