Hi all I have taken the plunge and gone all out to mp3 and purchased Virtual DJ Pro with the DAC3 controller and M Audio Pro sound card, I now have the job of making it all work.
Some questions if any of you could help?
1. Which is the best skin to use with the DAC3 controller, I also intend to play some videos as well.
2. Is it simple to set up the soundcard etc, I will still be using my mixer so would like to split the channels.
3.Is there any way that virtual DJ can auto DJ back ground music so I create a playlist and it will run through it and cross fade the tracks in a decent manner im not to worried about it beat matching them.
Thanks for any advice you can give me.
geposted Tue 30 Jan 07 @ 1:34 pm
1. I suggest using DJ FORMAT's Vmix Series Complete (first skin in the downloads section.
2. If you have a 4.1 card or greater, this will be no problem.
3. Sure, just open you playlist window and click the enable/disable automatic mixing button
geposted Tue 30 Jan 07 @ 4:49 pm
