I just purchased the dj console mk2 but it did not come with the installation software. Is there any way to obtain this software here/online?
Can I connect this to VirtualDJ without the installation software?
geposted Tue 30 Jan 07 @ 11:20 pm
1. if it came retail from a shop
you need to contact hercules support for a new serial and cd
2. if you bought it second hand you need to buy vdj pro and download the drivers to use it
drivers/support
http://ts.hercules.com/eng/index.php
drivers/support
geposted Tue 30 Jan 07 @ 11:22 pm
yea just got it from guitar center. is there a number I can call??
Can i connect to virtualDJ without the installation software?
I have virtualDJ but how do I hook up the mk2 via usb?
geposted Tue 30 Jan 07 @ 11:24 pm
might want to take it back to the shop and demand a replacment
geposted Tue 30 Jan 07 @ 11:25 pm
last one :/ i bought it still cause i have virtualDJ but i did not know I needed the drivers/installation cd for the mk2 console. any know of a place I can get this now instead of having to return and wait till they get a new shipment?
geposted Tue 30 Jan 07 @ 11:27 pm
Hello!
Go to this link; http://ts.hercules.com/eng/index.php?pg=files_faq and select -> Sound cards -> DJ Controller -> DJ Console MK2
Hope it helps you!
Hope it helps you!
geposted Tue 30 Jan 07 @ 11:35 pm
thanks! i have the mk2 control pannel up and running.
i go to config in virtualdj and select the mk2 but i don't hear anything, do i have to set up speakers to the mk2 or should i be able to hear it from the computer speakers??
geposted Tue 30 Jan 07 @ 11:56 pm
need to conect the laptop to the mk2 directly
geposted Wed 31 Jan 07 @ 10:47 am
