Hey,
one last problem hopefully
im not sure if it has some thing to do with the sound card or not but when i select the option to have 2 TCV's it only receives input from 1 and plays it on both decks (in VDJ), so if i scratch on one deck it does it on both
Gear:
2 x Timecoded Vinyls
2 x Ministy of sound TT's (Cheap)
1 x DJM-400 Mixer
1 x Sound blaster X-fi Extreme Music sound card
Any suggestions would be Sweet.
Thanks
Gear:
1 x DJM-400 Mixer
Thanks
geposted Sat 03 Feb 07 @ 1:49 am
try autolatency in proformances
is the waveform to small or too large on the screen?
try using the cable for the deck that works with the one which doesnt what happens?aslo to rule that out and check ur tts are grounded
geposted Sat 03 Feb 07 @ 1:51 am
i have tried autolatency, unticking the box, when i swap over the decks they both stoped working
geposted Sat 03 Feb 07 @ 2:09 am
also when i pull back on the deck that works if i do it slow the track moves back but if i do it fast it goes all over the place back then forward
geposted Sat 03 Feb 07 @ 2:16 am
Ok i have got it all down to 1 tt working perfect i think it could be the input for the last channel i will continue to try and fix and give an update later
geposted Sat 03 Feb 07 @ 2:40 am
try using the headshell of the one that works on the one that doesnt , might be worn needles
geposted Sat 03 Feb 07 @ 11:57 am
