Microprocessor Intel Pentium 4 processor 3.0GHz with HT Technology, 800MHz FSB
Microprocessor Cache 512KB L2 Cache
Memory 2048MB DDR SDRAM (2 x 1024MB) at 333MHz
Memory Max Maximum Memory 2048MB DDR SDRAM (2 x 1024MB)
Video Graphics Nvidia GeForce FX Go5700
Video Memory 64MB DDR (dedicated)
Hard Drive 80GB (4200RPM) Hard Drive
Diskette Drive External USB Floppy Drive available for customers via hpshopping.com or local retailers; $25 off purchase price for US customers only (before taxes, shipping & handling) reimbursed via HP mail-in rebate.
Multimedia Drive DVD+R/RW and CD-RW Combo Drive
Display 17.0-inch WXGA+ High-Definition Widescreen wide viewing angle (1440 x 900) Display
Fax/Modem Integrated v.90/v.92 56KB modem (RJ-11 connector)
Network Card Integrated 10/100BASE-T Ethernet LAN (RJ-45 connector)
Wireless Connectivity 54g 802.11b/g WLAN with 125HSM/SpeedBooster support
Sound 16-bit Sound Blaster Pro-compatible audio; internal Harman/Kardon speakers; AC audio link; volume control button and mute button
Keyboard Notebook keyboard with scroll bar and integrated numeric keypad
Pointing Device Touch Pad with On/Off button and dedicated vertical Scroll Up/Down pad
PC Card Slots One Type I/II/III 32-bit card bus (also supports 16-bit)
External Ports Four Universal Serial Bus USB 2.0
One Parallel SPP/ECP standard interface
One VGA (15-pin)
One RJ-11 (modem)
One TV-Out (S-video)
One RJ -45 (LAN)
One port replicator connector
One headphone-out
One microphone-in
One IEEE 1394 (FireWire)
One FIR (Fast Infrared)
Dimensions 15.67 inches(L) x 10.94 inches(W) x 1.67 inches(front H) 1.85 inches(rear H)
Weight 9.5 lbs
Power 120W AC adapter
12-Cell Lithium-Ion battery
Operating System:
Microsoft Windows XP Professional Edition
One VGA (15-pin)
One RJ-11 (modem)
One RJ -45 (LAN)
One headphone-out
One microphone-in
Weight 9.5 lbs
Operating System:
geposted Mon 05 Feb 07 @ 6:16 pm
You can view a list of recommended requirements on this website
geposted Mon 05 Feb 07 @ 8:07 pm
yes but you might have hicups for video mixing with only 64 meg of vram
geposted Tue 06 Feb 07 @ 2:48 pm
