Forum: VirtualDJ Plugins
Topic: Can't Get Sonique To Work Properly.
I have the sonique plug-in selected to be used when I don't have a music video playing. I can't get it to change automatically (it runs the same visual everytime it is used for the entire song). It is a real pain to keep opening the effects window and having to select a new visual every 30-45 seconds and for each new song that doesn't have a video. Unless I was misinformed I thought it was supposed to randomly run through the different visuals automatically.....if not, is there a plug-in that will do this?
geposted Tue 06 Feb 07 @ 11:13 pm
cstollPRO InfinityMember since 2004
Go to the effects section, highlight the Sonique plugin and activate the SLIDESHOW (button) option of the effect. Then slide the first slider for the delay of change - put it about 1/4th from the right.
geposted Wed 07 Feb 07 @ 12:03 am
Stupid me, I thought that was for the "Slideshow" plug-in. Thanks
geposted Wed 07 Feb 07 @ 4:06 am
