Hi guys, can vdj play vob files from DVDs? I tried it but it gave me "error in video driver" and can hear audio only. Please help !!!
Thank you!!!
Thank you!!!
geposted Thu 08 Feb 07 @ 5:10 pm
this sounds like a problem with your video card. vdj's hardware acceleration my not work with your video card. what kind is it, and what do you have selected on the video config tab in vdj.
geposted Thu 08 Feb 07 @ 5:15 pm
You may have a codec problem also.
You can try downloading from this link:
http://www.free-codecs.com/download/K_Lite_Mega_Codec_Pack.htm
geposted Thu 08 Feb 07 @ 9:07 pm
I have ATI MOBILY RADEON Xpress 200
and in video conf I have: check use hardware acceleration and in options check Linked crossfaders. sctive on load and Hide Logo
geposted Fri 09 Feb 07 @ 12:37 am
i have that card.....when i got that msg unfortunately i also got the database corrupted also......
1) under codecs make sure you have the vob video decoder on the list (i think it is by default)
2) get cstolls .xml tool......set it to run on every shut down and it will automatically check /repair/backup your database......that's one of the free plug ins
geposted Fri 09 Feb 07 @ 3:43 am
