Why does the Rhythm Window go right to left?
I ask this because the wave form on each deck goes left to right
and
the -/+ pitch adjustment... the - (to slow down) is on the left and the + (to speed up) is in the right. This matches the deck wave form direction but not the Rhythm Window direction!
and
geposted Fri 09 Feb 07 @ 8:44 am
You can change it. Config>options>scrolling>inverted.
geposted Fri 09 Feb 07 @ 9:07 am
This is why you have 5 stars and I have 3.... (-:
geposted Fri 09 Feb 07 @ 9:24 am
I help you, because some one helped me. Next week, you might help me, because I don't know shit.
geposted Fri 09 Feb 07 @ 9:31 am
its like karma do onto others as you would them have onto you ect :)
geposted Fri 09 Feb 07 @ 12:50 pm
