hi,
since i started using vdj.1 on my mk1 controller it hasn't been the same.
presently all i get is "directx sound driver error".
can this be fixed? how?
geposted Mon 12 Feb 07 @ 12:19 am
You need to dowload the latest directx from http://www.microsoft.com/downloads/details.aspx?familyid=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
geposted Mon 12 Feb 07 @ 12:22 am
Its usually not what it seems...
"DirectX driver error" usually just means that the current souncard setup in VDJ is wrong.
So just go to soundcard setting, make sure it correct set, and restart VDJ, and see the message gone ;)
geposted Mon 12 Feb 07 @ 12:43 am
Also - Since the MK1 is USB make sure you are always using the same USB port each time.
geposted Mon 12 Feb 07 @ 3:37 am
