Hi All,
Since a few days, and I can't seem to find out how, both the master signal and headphone signal get recorded while recording a mix. Although only 1 channel/fader is opened, and the other one is fuly closed - the one that I'm prelistening to - , Virtual Dj records them both.
So the signal which you normaly only hear in the headphones gets recorded along with the master signal, although the fader of that channel is fuly closed - so you can't hear it.
I can't seem to find the option to take care of this..
Does somebody have any ideas on this?
Thx & cheers
Thx & cheers
geposted Mon 12 Feb 07 @ 6:08 pm
what recording mode are you using?
geposted Mon 12 Feb 07 @ 6:27 pm
Record from Master (see config in recording tab) - Wav or Mp3
I'm working with an external mixer but it used to work, even with the mixer.
Any ideas?
Any ideas?
geposted Mon 12 Feb 07 @ 6:32 pm
im having the same kind of problem when im recording. this only happens when you use the vinyl mode.
geposted Tue 27 Feb 07 @ 3:21 am
