topic changed to info on what people need for vdj
geposted Tue 13 Feb 07 @ 1:30 am
i have a question for you... if i get 2 xp10's and a dac3...what mixtable would you recomend
geposted Tue 13 Feb 07 @ 9:07 pm
turntables you mean ?
if you live in the uk check these guys out www.decks.co.uk
geposted Tue 13 Feb 07 @ 9:36 pm
yeah ive been at that website for the past couple of days.. but no im not in the UK.
and i thought if i had xp10's i didnt neccesarily need turntables...just a mixer right. i am very very new at this..but i want to do it right. so 2 xp10's, a dac3, a mixer, virtualdj....im set with that right?
geposted Wed 14 Feb 07 @ 1:55 am
you might want the dac or the xp10 as they sorta do the same jobs
except the dac adds the ability to load songs
however with the mappers here it is possible to change all the behaviours of both
if i was going to buy just one id get two xp10s
you need a mixer , vdj and a soundcard which will support 4.1+ output or above
geposted Wed 14 Feb 07 @ 1:59 am
