Hi,
I just completed the default skin in order to make it perfect with Hercules DJ Console.
I added VU meters.
I added a fader for the headphone mix
And i added buttons to select the action of the jog wheels (Nudge or scratch).
Which make the default skin very complete (for my use at least).
The main default is that the VU meters don't exactly fit, then they hide the corner of the volume fader when it is down (which is nothing for mixing, but not so pretty for the look).
And the other thing is, when you select the scratch mode, the button goes green, and when you select the nudge mode, the button doesn't go green ! I don't understand why.
It's just a "nice looking" problem, but everything works perfectly, ans i really enjoy it.
then, if someone wants it, just tell me, and i send you the skin.
I added VU meters.
geposted Mon 23 Aug 04 @ 12:26 pm
hello...
why don't you upload it, then whe all can see....
geposted Mon 23 Aug 04 @ 10:52 pm
uuuh... i don't know how to do it...
geposted Tue 24 Aug 04 @ 11:54 am
Hi, go to the add-ons section, than skin, and on the top you'llfind "instructions", with the link for the upload.
Ciao!! :)
Ciao!! :)
geposted Tue 24 Aug 04 @ 12:40 pm
Go here to submit your skin:
http://www.virtualdj.com/addons/submit.html?addon_type=1
File name is the .zip file (on your harddrive), and 'Preview' is a 200x150 jpg image (optional) that will show up in the skins section :)
macourteau
macourteau
geposted Tue 24 Aug 04 @ 1:49 pm
Alright, i submitted it. Thanks for the tip.
Rémi
Rémi
geposted Wed 25 Aug 04 @ 4:07 pm
Where is this skin? Anybody?
geposted Mon 06 Jun 05 @ 3:38 pm
The team needs a litlle time to test before to set it available for downloads.
geposted Mon 06 Jun 05 @ 8:35 pm
The post was aug2004 search for the skin that was written by rchautard and you'll get it.
geposted Mon 06 Jun 05 @ 8:56 pm
Thank you, I am always looking for a easy to use skin, easy on the eyes with the buttons in the right spot, any other suggestions would be appreciated.
geposted Mon 06 Jun 05 @ 9:20 pm
Okay here is RemiSkin:
http://www.virtualdj.com/addons/download.html?addon_id=589
geposted Mon 06 Jun 05 @ 9:31 pm
Oups I was wrong with the datum. ~
Too early for me .... I'd better go back to my bed. ~
geposted Tue 07 Jun 05 @ 6:30 am
