1. I've tried to tweak some settings to see if I could use my TCV to basically cue and launch the song. Are there any proper settings in 4.2 that can beatlock/sync with ease? It seems that everytime I press SYNC it skips the beats around violently.
and
2. What are the proper settings to make a true vinyl sounding "scratch"? The settings I have currently sound a bit garbled and slow in catching up to the movement.
If I can combine both of these settings then I will be a happy camper. Suggestions?
    and
geposted Wed 14 Feb 07 @ 6:49 am
          what is your system spec
to start off i recomend on the proformance tab you choose "autolatency" this should solve the jumping beat.
geposted Wed 14 Feb 07 @ 12:28 pm
          Toshiba Satellite Dual Core r25-33503 Tablet PC
Intel(R) CPU
Windows XP Service Pack 2
T2050@ 1.Ghz
.99 GB of RAM
100GB with 45 gigs free space.
Updated Direct X
Updated Drivers
Free RAM accelerator
Disable all or most Processes
Fatest Performance-
AutoLatency
30min max load
Hardware Acceleration is on
Proper Ventilation
Running skins with proper resolution
Using
TCV thru Serato
5 Channel Mixer.
Shure 44's (new)
USB Midi Trigger Finger
Virtual DJ 4.2
Sonique Visuals
Intel Graphics card
    Intel(R) CPU
T2050@ 1.Ghz
.99 GB of RAM
Updated Direct X
Updated Drivers
Fatest Performance-
AutoLatency
30min max load
Proper Ventilation
Using
TCV thru Serato
5 Channel Mixer.
Shure 44's (new)
Virtual DJ 4.2
Sonique Visuals
Intel Graphics card
geposted Thu 15 Feb 07 @ 6:22 am
          ok keep autolatency
choose Optimise Stratch for "quality"
and try , advanced lowpass filter
geposted Thu 15 Feb 07 @ 12:36 pm
