I usually use VDJ on my laptop, but i loaded it onto my home computer just to see how well it would work, and i'm amazed! really smooth video mixing and it's only got an intel shared graphics memory card.
The only tiny problem is that i get a see through green stripe down the middle of the VOBs when i'm playing them, probably appears for about a second, then disappears for a around a second or two and come back again. Any suggestions how i might get rid of this?
The stripe shows up in the preview window of VDJ and the video output window as well.
Any help with this would be great.
Thanks. :)
Thanks. :)
geposted Wed 14 Feb 07 @ 12:51 pm
is hardware excelaration enabled on the video options?
geposted Wed 14 Feb 07 @ 12:54 pm
yeah, but i'm not sure what exactly it does through, because it's only the standard graphics card that came with the computer.
geposted Wed 14 Feb 07 @ 1:03 pm
it enables the higher funtions of ur card and it allows the video fx to run
do u get the green stripe in other aplications ?
geposted Wed 14 Feb 07 @ 3:48 pm
It usually means your graphics card doesn't have enough memory. You need a more powerful card.
geposted Wed 14 Feb 07 @ 5:30 pm
that's cool, if i decided to use it for work, i would have upgraded the video card anyway. Just wanted to know if that was the problem or something else.
Thanks. :)
Thanks. :)
geposted Thu 15 Feb 07 @ 10:21 am
a green stripe means you dont have enough video memory? who told you that?
geposted Fri 16 Feb 07 @ 1:15 am
its because its not rendering it right , can aslo be caused by bad codecs
geposted Fri 16 Feb 07 @ 1:17 am
wrong answer i had the same problem and i fix it w/ an update of the video driver
try that first
try that first
geposted Fri 16 Feb 07 @ 9:33 am
