Forum: Old versions
Topic: Numark's NuVJ is compatible [controllers] with VDj?
Hi guys,
I'm newbie on this forum, and I know what for is "search" button :). I'm thinking about best interface for me [audio+video with scratching and mixer built in]. NuVJ look very professional. Is possible to use this controller with this soft? I'm a pro dj, but now I wanna mix videoclips maded by me. Pioneer DVJ is too expensive for me, so I looking for soft+interface alternative.
geposted Fri 16 Feb 07 @ 4:19 am
Hey... In the most part it is compatible... but I can't seem to map the jogs... other than that... I have everything working... let me know if anyone has a solution to this...
I have the same problem.
The settings as a Relative Mode do not function. Must a value be put down?
Have you thought about the Total Control instead?
They're both pretty similar, but the total control is natively supported in virtual dj, so no mapping problems.
Yes, but this also does not function.
Only the knobs (for EQ and browser searching) & jogs cannot be map. The buttons wunderfully work.
Is the NuVJ Controller connected, in the remote control settings for TC seems not connected.
Everything can be put without difficulty with the exception of the rotary knobs & jogs.
Also not with the setting "Relative" or "Absolut".
No ideas ?
:o(
I tried it out.
Jogwheels do not function, and the buttons rotate too fully clockwise or fully counterclockwise, but did not step by step (like a level- or gain regulator)
:o(
