I have the songs loading into my decks too slow!! the song loads ok, but it's slow, example for a six minutes song it's about 30 seconds of loading! it used to be a lot faster before and i cant find what happened!
Can someone help me?
I use a external hard drive Acomdata 160gig usb 2.0
Hp pavillion 5615ca 512 ram
Celeron 2.80 ghz
I really doubt that it is the laptop or the hard drive since it worked perfectly before... i puted it on network could it be the problem?
Thanks again!
Celeron 2.80 ghz
Thanks again!
geposted Thu 22 Feb 07 @ 3:43 am
What format are the files? I noticed for me that .wav files took considerably longer than mp3s.
Obviously with the advent of using an external HDD, it's going to cause a small slowdown. You could always test this theory running a speed comparrison with Simpli Softwares free HD Tach program.
Best of luck. I'd love to hear your speed results for the HDDs =D
geposted Thu 22 Feb 07 @ 11:40 am
are you using xp?
geposted Thu 22 Feb 07 @ 12:10 pm
Make sure that "SpeedLoad" is set to "1" in the registry.
When this is set to "0", audio-only files load slower after any video file has been loaded. I'm not really sure about the reasoning behind that, but I think it was to give the perception that video and audio files load in comparable amount of time on older hardware.
geposted Thu 22 Feb 07 @ 6:01 pm
how can i edit this in the registery? what is the procedure?
Yes i am using Xp
Before my External hd was loading perfectly, i suspect that i pluged it on home network, i don't know, i am formating right now so i can start back from scratch
Yes i am using Xp
geposted Thu 22 Feb 07 @ 6:19 pm
I DId it! everything is working fine! only one thing, the hercules console is instaled but i dont have the little icon in the status bar down right.... anyidea why? (i know its not the proper topic)
geposted Thu 22 Feb 07 @ 6:26 pm
now i have some crackles and the songs (mostly slows) sound like old vinyls... what to do? i have read all the crackles and pop problems over the forum but none fixed it :(
geposted Thu 22 Feb 07 @ 8:19 pm
Reinstall Hercules drivers. DO NOT update to the newest (Vista). Keep the previous ones.
geposted Thu 22 Feb 07 @ 11:33 pm
man, it's back, the files load 75% slower than it should..... DAMN :( I start to freak out here...
geposted Fri 23 Feb 07 @ 4:25 am
i have to put my reactivity to SLOW to have a decent load time..... it's really not good for the visualisation of the waves...... oh man what is hapening??
geposted Fri 23 Feb 07 @ 4:50 am
geposted Fri 23 Feb 07 @ 12:38 pm
Your ram is also on the low side...
geposted Fri 23 Feb 07 @ 4:01 pm
You could also check the following setting in the configuration menu:
- VDJ Config menu
- Video tab
- Video output -> Activate -> Disable (not checked)
Ewout
- VDJ Config menu
- Video tab
Ewout
geposted Fri 23 Feb 07 @ 6:56 pm
it's fixed, i bought a new laptop! lol
here is the thing:
AMD Turion 64X dual cores 1.66Ghz (512 L2cache)
1 gig ram
120 gig hd
Radeon express 1100
15,4' screen
here is the thing:
1 gig ram
120 gig hd
Radeon express 1100
15,4' screen
geposted Sat 24 Feb 07 @ 1:20 am
sweet!
geposted Sat 24 Feb 07 @ 1:29 am
Oh yeah man it's so good to mix with darn fast loading! Amen!!!
geposted Sat 24 Feb 07 @ 3:17 am
For future reference, the key word to look for is CELERON. Do not expect any program that does any math intensive operations to get done quickly with a Celeron chip. That is why it is so much cheaper than a regular Pentium 4.
geposted Sat 24 Feb 07 @ 3:26 am
yeah i got the lesson now, nevermore celeron! but now i have instaled the vdj and mk2's but, i can't load wma's.....is there a codec pack downloadable?
geposted Sat 24 Feb 07 @ 3:30 am
check on the vdj codec options wma is set to wma (DRM) decoder:)
geposted Sat 24 Feb 07 @ 3:45 pm
thanx a lot
geposted Mon 26 Feb 07 @ 7:00 am
