does anybody know the search capacity database for virtual dj 1.o, 2.0 and 4.0?
geposted Fri 23 Feb 07 @ 5:57 pm
Why do you need to know this for version 1 and 2?
Please download the latest demo version here from this website (Version 4.2). The search is good and very fast. You have to do the following:
- Rename your file properly
- Scan your drives: Click right on local database in the browser and select Scan HD
- Click the local database to search trough all your files
- Select a folder for searching through that folder.
Ewout
Ewout
geposted Fri 23 Feb 07 @ 6:46 pm
First off the DB is an XML file and the largest file size I have experienced it 30Mb - which is alot of tracks and it's VDJ info (cues, fade points, etc)
geposted Fri 23 Feb 07 @ 9:38 pm
