i have set uo the bcd 2000 behringer controller
is use vdj 4.2 and configured the bcd 2000 as a remote control
some of the buttons dont work
like the loop in button
ans sync slave
pitch bend
does anybody now what up? and how can i solve this problem?
thanks
ans sync slave
pitch bend
thanks
geposted Fri 23 Feb 07 @ 11:37 pm
From the config of VDJ, Remote controls, enable Midi press Config then Load and select the MIDI-BCD xml file. Your BCD-2000 will work as a MIDI (no leds). You can change the buttons the way you like them.
If you buy VirtualDJ you could download the BCD-2000 Mapper and some BCDLook skins. Then everything will be working (included leds) except the MIC.
geposted Fri 23 Feb 07 @ 11:50 pm
