How can some one create his own xml..? i want to create my own xml of bcd2000 can someone help me how to do it?
geposted Sat 24 Feb 07 @ 4:28 pm
why not use the midi mapper on the remote control tab instead it will be easyer :) and more accurate
geposted Sat 24 Feb 07 @ 5:25 pm
Sure you can. From the Settings of VDJ choose The CONFIG button of Midi in the Remote Control Tab.
There, you can modify or create everything you need and then SAVE your New MIDI Commands as an xml file.
Leds will not be working, unless you use the Moramax Midi Mapper (only for proffesional edition users)
geposted Sun 25 Feb 07 @ 7:27 pm
