Topic: Vocal+ removal problem with timecode
Ok, now its been a while (9 months since the birth of my son), so i haven't had much time for vdj.
But never had any problems in the past.
Anyhow, I decided to have a spin today. And despite the usual problem of having to re-install the maya 44 usb drivers (as i do every time i restart my computer and want to use vdj, dunno if this is a common promlem?), I started mixing a nice little set, Then it came to the point when i wanted to use the vocal+ plugin, and BAM!, the timecode went all wierd, on both decks, until i stopped the deck the vocal+ was on and then the other deck carried on as normal. Then turned off vocal+ and everything was fine again.
I tried setting the performance settings to most basic and still have the same trouble.
I believe my system should be able to handle it:
Asus Laptop
Duo T2300E 1.66ghz
1gb Ram
ATI X1600 graphics (256mb)
I have 2 ttx1's
And fairly old tcv (prom 1st Generation)(i believe we are on 3rd Gen now, would that make much difference, generally?)
Thanks
geposted Sun 25 Feb 07 @ 11:37 am
for me it works fine but if you rewind a deck that has vocals + or flanger on it then the audio starts skipping. think its cause of the forward looking way the effects have been developed. i havnt found a way round this (other than making sure i dont do it)
and capdown kick hench ass, as does london
