Forum: Old versions
Topic: Is there a way to import playlists?
Hi. Im new and want to know if there is a way to import either an iTunes or Windows Media Player playist in VirtualDJ?
Any Help Appreciated!
geposted Sun 25 Feb 07 @ 11:39 am
As far as i know you can only import itunes playlist... Right click onto local database the select import itunes database....!
geposted Sun 25 Feb 07 @ 11:49 am
geposted Sun 25 Feb 07 @ 12:22 pm
sbangsPRO InfinityMember since 2004
dont need to mate just follow the steps already mentioned will do it all for you :)
as to the windows media playlists save them as .m3u or .pls and load those :)
geposted Sun 25 Feb 07 @ 12:32 pm
To import iTunes playlist you can just right-click on the very left part of the music browser, at some empty space (not at a folder of file), and the "import iTunes.." will show..
It will make a VirtualFolder for each iTunes playlist
hope that helps ;)
geposted Sun 25 Feb 07 @ 3:09 pm
bogartPRO InfinityMember since 2004
Why make playlists in another program when you can make it in VDJ .
Open VDJ and locate songs you want.
Put them in the playlist section.
When finished selecting, just name and save the playlist.
geposted Mon 26 Feb 07 @ 8:55 pm
Hi there,
Is there a way that VDJ reads the m3u playlists made in windows media player?
I know VDJ reads them from the original location, when they are saved as m3u formats.
But...is it possible to import the playlists directly from the media player?
My music on it's original location(external harddisk) is a mess, but in the media player it's totally organised, would be heaven for me if VDj could read THOSE lists from the media player. (Seems to be possibe with i-tunes, 90% of laptop users have a pc, so it should be possibe, I hope.)
Anyone out there who can spent some moments on this one?? Please.
Bye, regards
Floor
geposted Tue 15 Mar 11 @ 5:56 am
I know this is an ancient thread, but here's how to import .m3u playlists to Virtual DJ:
1. Export the playlist from Winamp, Windows Media Player, etc...
2. Hover over the playlist panel
3. Click the lock icon to keep it open
4. Drag the .m3u file into the playlist panel
That's it!
geposted Sat 09 Nov 13 @ 6:55 pm
Import Itunes playlist is very easy. Remember to save you playlist first in itunes
open vdj 7 pro, go to config
click on browser and tick Show Itunes
vdj will automatically show your itunes playlist.
hope this help
geposted Sun 12 Aug 18 @ 10:41 am
hrdnxPRO InfinityMember since 2011
Really!!!!!!!
Replying to a post from Nov 2013???????
geposted Sun 12 Aug 18 @ 10:55 am
Please don't open old threads, thank you.
Locked by AMAHM
geposted Fri 24 Aug 18 @ 8:46 pm
