I am looking for a bit weird software/program... i want to make a list/database i don't know , of the song curently in my laptop. I want to do this so i can remove any duplicates and so i can share with a fello dj wich is going to get a mk2 (because of me lol).
I know that he has some songs i want but instead of going through the whole library.....
Anyone?
Anyone?
geposted Mon 26 Feb 07 @ 7:02 am
Hi
Try Music Magic or PMP both developed by Ultraselect Software.........
http://www.musicmagic4u.com
Good Luck
Good Luck
geposted Mon 26 Feb 07 @ 8:54 am
MusicMagic and PMP are both great softwarew. However I not quite sure it eliminates duplicates. It may find them and tell you the location of each. Then it will be up to you to delete the one you want deleted.
DJ Angel S
DJ Angel S
geposted Mon 26 Feb 07 @ 6:22 pm
i have cheked and i can't find pmp... and music magic does work but with cd's mostly...
i use a external hd and my songs are all messed up... i need to rename a bunch on em and some don't even have the right name (unknown artist, track 01.mp3)
Anyone have an idea to put some order in there..?
geposted Tue 27 Feb 07 @ 8:16 pm
Tag n rename will help you along with musicmagic4u.com
geposted Tue 27 Feb 07 @ 9:36 pm
Karens directory printer will print or save to a txt file for the contents within a folder or volume...
geposted Wed 28 Feb 07 @ 11:54 am
